88 k5 hi speed blower
Hi speed works intermittenly on ac/heat...Put in new resistor, no help...Could it need a new relay???
Possibly I would test to see if it is bad first though.
i had a k5 that did the same thing, and it ended up being the blower motor itself. and this was after i changed the resistor 3 times and the relay twice..
hope this helps Ck1500 |
I'm having the same problem replaced the motor and relays. But no change low and med work but no high. the relay that controls it does activate i have to trigger it manually and it'll work. could it be the controller?
Did you ever trace down the issue?
I have had that very issue with my 88-K5 since the day I bought it. I was told there is both a resistor, and a relay, but the only one I know about is the one mounted on the side of the air conditioning housing.
hi speed blower problem
Originally Posted by geoworley
(Post 338923)
I had this problem when I got my '89, and it turned out to be corroded contacts on the heavy gauge purple 12v wire where it hooks to the blower motor. I replaced the factory connector with a large female spade connector and it's been fine since, except when I pulled that wire loose once...
