Auto to manual swap. What is the factory manual transmission called?
I want to swap my automatic transmission for a manual transmission. I want to install the factory manual transmission. Big Red currently has a 700r4 automatic and a New Process 208 transfer case. What is the factory manual transmission?
You can use an SM465 4-speed. I'm not sure the K5 was ever offered with a 5-speed.
The hardest part of the swap is the pedal assembly. The rest is pretty straightforward. Let me know if you need parts. I think I have most of them (except for the transmission itself).
Yeah - SM465 is the 'stock' on the K5. Only thing I'd caution on though is the clutch assembly. Mine (87 K5, 305/SM465) has the hydraulic setup on it. It took me MONTHS to find a SM465 hydraulic bellhousing that wasn't boogy-dollars and unbroken. Ended up getting a whole setup to replace my broken bellhousing. I've heard you can do a cable setup - but I'm not really familiar with it.
Traxxas14
08-23-2009 10:11 AM
