-   Full Size K5 (1969-1991) GMT415 (1992-1994) Tech (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/)
-   -   Ball joint gap??? (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/ball-joint-gap-74530/)
ptenhet 10-15-2012 11:17 PM
Ball joint gap???
We are redoing my son's 1986 K5 suspension. Normally I would take pictures before I take things apart, but I thought it was straight forward. We replaced all of the ball joints, but ended up with a large gap on the uppers. I don't remember if there was a gap with the old ones. Does this look correct? The replacement ball joints look the same...
http://imageshack.us/a/img37/3581/upperjnt1.jpg
http://imageshack.us/a/img222/4386/upperjnt2.jpg
70-K5 10-16-2012 11:31 AM
Will the hubs still line up with the axle tube?
abig84 10-16-2012 01:47 PM
if there is no movement in and out of the knuckle and the top nut went down far enough to get a cotter pin in there it will probably be fine. ill be in my garage tonight when i get home and ill look to see how mine is
