Blazer not running fuel issue?
So I bought an 85 K5 last month. When gas tank got to a half tank it started running rough. I filled up ran like a champ... well got to half tank and again running like crapola. So I replaced filter in carb. There are no in line filters. I am back to a full tank. So dropping the tank would be a PITA. It will not stay running without pedaling. If I drive it will bog and die. It's hit or miss.... If I stomp on it..... it will stutter the pickup quick then bog down and stutter again.... I think it may be a gas issue. I put a bottle of heet in tank for moisture no help..... Is there some type of filter in the tank? What would you suggest?
diffinitly sounds like a fuel delivery problem! Does it do this hot or cold or if you run it from full to half non stop does it do this? Is it popping like its lean or is it act like its loading up and dying? Just trying to give you a better diagnosis!!
Originally Posted by HiRidinChevy93
(Post 411382)
Your fuel pump should be mounted to the engine on the front passenger corner. You could be experiencing a weak pump. The lower the fuel level in the tank, the harder the pump has to work to get that fuel out. Or, you may be experiencing a problem with the pickup tube inside the tank. If the pickup tube had a hole in it, it would cause the pump to suck air whenever the fuel level drops below the hole.
The pump is easy enough to change out and at a typical price of $15-$20, it won't be hard on the wallet either. This would be the first step I would take. Here is an image I took from the engine out of my Chevelle for someone else quite a while ago. It shows the pump, how it's mounted, and the pump push rod retaining bolt location (where applicable). http://i11.photobucket.com/albums/a1...el_pump_01.jpg |
Originally Posted by swartlkk
(Post 411885)
Which bolt? The one in the front? If so, just take one of the two bolts that hold the pump on and use that. They are long enough to get in there and retain the pump push rod. Hand tight is good enough. It just has to hold it well enough that gravity doesn't let it drop down into the lower cavity.
IIRC, you'll need a 9/16" wrench. Having a liner wrench helps get the fuel line off the pressure side of the pump (what runs up to the carb). |
(Post 412154)
IIRC, you'll need a 9/16" wrench. Having a liner wrench helps get the fuel line off the pressure side of the pump (what runs up to the carb). Great thanks for the update. :icon_shrug: Hand tight does not work :icon_shrug: So I turned the long bolt with wrench two turns and the rod was still loose. No connection, so I backed the bolt out and it was really tight. I hate to force it. Would you suggest keep going until it touches? Thanks again |
Originally Posted by TheK5
(Post 412386)
:icon_shrug:
Sounds like you have it installed correctly, but it's worth a try at switching the lines. Did the new pump come with anything stating the function of each port?
(Post 412705)
