Can't Find Oil Pan Gasket That Fits
I am building a 1986 K5. I dropped a 1980-1985 small block in it:
back in the day that probably never came as a one piece
Victor gaskets made a set called "tough cork" Still a multi piece but the cork sides have a metal rib sandwiched in between layers of cork I like a skim coat of Permatex #2 and a little dab where it transitions to rubber If everything is clean for assembly you shouldnt have any seepage down the road |
No rubber gasket
You're right. I can't find a rubber gasket so I went with an old-style 4-piece gasket. It fits good but will be a pain to clean up if I ever need to change it out.
