clunk
theres a loud clunk when i put it in reverse like its engaging real hard what would cause that
Either its bad u-joints,rear end,or trans. Check the u joint for wear/play 1st before anything. if that turns out good,jack truck up,add safety jacks,remove the driveshaft. then reinstall it to the rear diff only. turn the driveshaft back and forth to see how much play you have before the wheels move.
i just replaced the back u joints could it be the front ? also its a diff trans and rearend
Originally Posted by 89stlblazer
(Post 448141)
ill check and get back to you
