"D" or "OD"
Ok, boys and girls. The '85 350 stumbles and bumbles in "OD". I have to keep pumping the gas pedal just to keep it going. However, if I'm in "D", it runs a whole lot better, no hesitation, I don't have to keep on pumping the pedal to keep it going. Thoughts and ideas, please. Thanks.
HMMMMMM. im guessing you mean it stumbles while say your cruising 55 mph in 4th gear? My guess is you have carb issues and its not liking the low rpm of the 4th gear much. You said you have to pump the pedal....I say its the carb needing rebuilt.
well if its while cruising it could be a torque converter issue or a TV cable issue,
i had a beater s10 that had a similar issue, you can never just cruise with it, always had to be down a gear and have some rpms up. ended up being a issue with the accelerator pump in the carburetor for whatever reason it was allowing excess gas into the engine. just something to look into
Originally Posted by Z71_Guy
(Post 472893)
Originally Posted by abig84
(Post 473033)
Originally Posted by chris015
(Post 473076)
read what abig84 said below you.
Exactly. I had a carb'd truck with od and it hated the low rpm's until i had the carb rebuilt. |
(Post 473078)
Im just giving other possibilities no need to be like that. I work at a shop and its not always the common thing that make a problem happen.
Can I just drive the damn thing in "D" and be done with it, or will it screw up something else???
if it drives good in drive,go for it. you will just have some crappy gas mileage. but some awesome throttle response. lol but if its stumbling in od, and its the carb,one day or another its gonna do it in drive....id start calling around some old corner carb shops and see about a carb rebuild.
I use drive when i tow my trailer
gives me a lot of rear end torque and feels like theres an engine brake going down hills Like the big rigs have ! |
