DEAD 1990 Full size (350c.i.)
Ran fine. Starter arced, replaced. Ran fine, then cranks but no run. Tested> weak or no spark, AND injectors not pumping ((Fuel pressure great @ throttle body.))
--Replaced Ignition Module (under cap) -old one tested fine but repl. anyway. --Bought pickup coil> but havent installed yet. DONT WANT TO KEEP THROWING $$$ AND/OR TIME INTO IT. >>>>>>>ANY SUGGESTIONS APPRECIATED<<<<<<<< |
Did you have the coil tested?
I have seen a bad ESC (electronic spark control) module cause a similar issue (weak spark and no power to the injectors). BTW, I have moved your post into the appropriate section. Please try to post questions in the tech sections relevant to the vehicle and/or type of problem you are working with. |
the ESC went out on my 1990 K5 and once i replaced that its ran awsome ever since
