Drive shaft Vibrations
I have a 1988 Full size blazer that I just installed a 4inch lift and when I took it for a test drive down the road I noticed that when I let off the gas, I could feel and hear what seemed to be my rear drive shaft vibrating. As soon as I got on the gas it would stop and start again when I let off the gas again. Any ideas what would cause this. Anything helps.
Could be the u-joints or could possibly be a worn slip yoke at the back of the transfer case.
Did you have the drive shaft off?
Yes I had my drive shaft off and I had my buddy looked at my U joint and said it was good, but now I'm just going to replace it anyways. I it look old to me.
High mileage u-joints will vibrate when their "worn in run patterns" are changed with things like greater angle due to a lift. Should be an easy fix with new u-joints.
Originally Posted by Straka88
(Post 252141)
| All times are GMT -5. The time now is 09:40 AM. |
