Emergency Brake Engaging
Hi, I have an 87 4x4 Diesel Blazer K5, and I have just replaced some parts in the drum brakes in the back plus fixed some old parts in the front(ball joints, u joint etc) And I have noticed that sometimes after the car is turned off and in park when I start to use it the next time the Emergency Brake is engaged but the pedal isn't pushed in.
What could be causing this? Thanks |
You may just have the brake shoes adjusted improperly. Try loosening up the fit a bit and see how that goes.
