engine stalls irregularly
hello everybody!
about a month ago my 90' K5 stalled while running. i tried to start it and it started with ease. an hour later it stalled again and started again with no problem at all. the problem disappeared for about a week and came back strong - i was driving, it stalled, i started it, it ran for a few seconds and stalled again, repeatedly. after a few times it refused to start. i had to give some time to cool down before i could start it again. every other day the engine stalls, and when it's not, it runs perfectly. i'm having trouble finding the cause to this mess - any help will be appreciated. yarin. |
Any codes?
You could remove your coil and have it tested. Same for the ESC (electronic spark control) module. |
last time i checked, no codes.
is there a particular way to test the coil and the ESC? |
Take them to your closest advance auto or autozone. They should have the proper analyzers to stress and test them.
thanks, i'll give it a try.
but let me get it straight - you're saying that a test with a multimeter is insufficient or unreliable? |
Most problems with these components surface when they are stressed (either by load, temperature, or a combination of the two). These two items would have to be in pretty bad shape for them to test bad using a multimeter.
it's been almost a month since i posted a message about my stalling problem. since then the truck ran beautifuly and never stalled, so i didn't replaced the ignition module and the coil like i was told to. last night the truck stalled at very low speed and started right back on. then i parked for a few minutes with my engine still running. then the rpm dropped significantly and came back to normal after a few seconds. and a minute later the engine stalled again.
i know i didn't replaced the parts i was asked to replace but i thought maybe this rpm thing might give you a new lead. yarin. |
It may be a result of a sticking IAC valve in the throttle body. I would remove and clean the throttle body, installing a new TB base gasket when you put it back on. Be careful with the fuel line connection at the back!
is there a way to check the IAC valve?
If you have the appropriate scan tool that is capable of bi-directional controls, yes. But start with removing the throttle body and cleaning it.
