Hard to steer
1985 K5 4X4. Hard to steer in tight spots and making turns. I have to pull hard just to make turns. It has power steering, resorvoir is full, it doesn't make any noise when I steer. It's just a pain in the ass to drive a basically powerless-steering vehicle. Comments, suggestions, offers to buy are welcome!!!
does the steering wheel only move like 1" at a time. kind of like the pump is cycling?
Originally Posted by blueblazer1982
(Post 364297)
mine does the same thing. check the bolts that hold the pump on. i think there is 3. i know on mine the housing is cracked on the pump. if they are all tight , i would look for a bigger pump from a 3/4 or 1 ton. epecially if you are running bigger tires.
(Post 364489)
i don't know for sure. chevy did a good job of keeping stuff close or the same back in the 80s. might be worth a trip to the junkyard just to see. you always come home with more than you planned too.
(Post 364497)
hey you said pick n pull are you in california?if you are i know a great place to pick up parts for old blazers in fremont
i found the problem on mine yesterday. the belt is loose on the pump. check yours . make sure it is tight. mine steers like a million times better
Originally Posted by ericthughes
(Post 365085)
(Post 365551)
