-   Full Size K5 (1969-1991) GMT415 (1992-1994) Tech (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/)
-   -   headlight mods / header panel question. (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/headlight-mods-header-panel-question-9913/)
2 Big Blazers Apr 6, 2007 07:57 PM
I have a full size 87 Blazer. I want too swap in the headlights, grill, ...ect from a early 90's GMC pick up. Same as 89 to 91 full size Jimmy. I need too know if I'll have too change he header panel or if can use the 87's. Are holes drilled and tapped, can I modifie the 87's ????
Chevy Lover Apr 10, 2007 02:16 AM
RE: headlight mods / header panel question.
I have a feeling that you also need to replace the rad support. There will be a few differences in the mounting of headlights and grille etc... Probably about $200 extra.
[IMG]local://upfiles/2910/A8DA0F43B9164F7BA0C268C3E31E478E.jpg[/IMG]
2 Big Blazers Apr 10, 2007 03:01 AM
A couple days ago I was up at the shop. I parked my 87 K5 next to the 89 K5 plow truck and popped the hood on both for a side by side compare. The header panel (AKA ... Radiator support) are almost the same. Looks like I might have too drill and tap a few holes, but other then that, everything looks the same. My 87 has knock outs for the 89 to 91 side by side headlights. No big deal either way, just a few more bolts, LOL.
