High speed fan doesn't work
Can anyone help on a 1980 (non computer truck) fan setting that does not work
on high ? I saw a post about high speed is direct not controlled by the resistor ? Thanks |
*Moved to a new thread in the Fullsize Tech section* - The thread you originally posted in was based on the 1st generation s-series and that information really is not applicable to your vehicle.
I don't have access to my references at the moment. In the meantime, maybe someone else does. Typically, high speed is a direct connection to battery voltage. If you do not have battery voltage at the fan, work your way back to the fan speed switch. |
had the same problem on my car replaced the resistor works now
