K5 blazer ABS / possible mechanic / fort worth
Old Oct 3, 2024 | 01:23 PM
Speed179's Avatar
Speed179 is on a distinguished road
Default K5 blazer ABS / possible mechanic / fort worth
Anyone have a good (reputable) mechanic in the fort worth, Tx area that works on older blazers? 1994 k5 here. While we do most of the stuff ourselves the ABS hasn't worked in years. Can't remember what was changed or replaced when it happened but I just got in a new (used but apparently tested) ABS module to swap out. Hopefully that does the trick but i do not and can not find a GM Tech1a scan tool for sale anywhere. I've watched videos on bleeding and finishing at the module, tried that with my old one but didn't work. Wasn't exactly sure how to even test the module w/o the scan tool to see if that was the problem. Figured if this doesn't fix it maybe someone in the area has the tool or knows of a shop that does.
**Update** ABS module replaced. Still no ABS, no ABS light. Any suggestions????
Toocute350
Jul 17, 2020 02:49 AM
tycobb280
Aug 8, 2015 10:18 PM
fixitmanmc
Apr 24, 2011 07:38 PM
warthogdriver
Sep 22, 2010 09:56 AM
samuknow
Apr 20, 2010 11:09 AM
