k5 tach.
i bought a tachometer to hook up to my 86 k5 blazer. its the 350 5.7 liter v8. im having some trouble finding the spot to put the green wire, i know its somewhere on the distributor but i cant find where, anyone know? or have a picture? thanks.
Im new to the site and i also jus obtained a tach and i was told on the lower rear
Should be like a litte prong
Its kinda under the cap. If you're staring down on the distriputor cap you will see a little square piece that comes out on the driver side. It will have a clip with 3 wires going up to it then a single clip with a red wire. Right next to that wire is where the tach plugs in. It should say batt where the red wire is then tach
Did you find one that fits in the stock cluster or are you mounting somewhere else?
