-   Full Size K5 (1969-1991) GMT415 (1992-1994) Tech (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/)
-   -   Need quick answer! Back Window Problem (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/need-quick-answer-back-window-problem-48102/)
mafiaboy01 Aug 19, 2010 02:52 PM
Hi, I have an 87 blazer with power windows, including the back.
I've had the motor rebuilt and a new cable installed not long ago and it's been working great.
This morning I pulled the window down to put some stuff in the truck, after that I tried to pull it up but all I could hear is the motor spinning.
After removing the cover I discovered that the cable has been disconnected/broken from the regulator.
My question is, how can I get the window to go up manually so I can take a look at what the problem is?
This is urgent because it's going to rain soon and my back windows is down!!!
Thanks for any help.
swartlkk Aug 19, 2010 04:51 PM
Is there anything that you can hook a drill up to on the cable? You can use a drill to raise the window.
mafiaboy01 Aug 19, 2010 05:49 PM
It actually disconnected on the other side so I had to remove the glass to reconnect the cable.
swartlkk Aug 19, 2010 06:05 PM
Ah. Yeah, if it breaks off the regulator, you have to unbolt the window and slide it up.
