need some help
Ok, I have a 94 2 dooe full size blazer with a couple of problems. One is that my headlights only work on brights, i check both bulbs and everything is ok. My other problem is that my abs light stays on all the time. Thanks for any help.
Did you test the headlights with a test light? or possibly your headlight dimmer switch is stuck? The dealership can scan your abs light issue to tell you whats wrong. You can pull the ABS fuse out so the light isnt on the dash and you will still have brakes(providing you dont have any other braking issues) you just wont have ABS.
