New to me 1994 Full Size Blazer- What to do?
I just picked up a full size blazer, 1994. What should I be looking to do to it for general maintenance right away? I've obviously changed the oil and filter, as well as the air filter. I've worked around under the hood, cleaning up some parts, priming and repainting them. The engine area is extremely clean now.
Let me know if I'm missing anything: change tranny fluid change rear diff fluid http://www.xtremepbma.com/joe/blazer1d.JPG http://www.xtremepbma.com/Joe/blazer1d.JPG |
dont forget about t-case and front diff, also brake, power steering and coolant. Tune up wires, plugs, cap, rotor, replace or clean PCV, grease all the steering joints.
thanks
replace the fuel filter, clean the injectors, make sure ac system works and is not leaking.
yea and check your rear. those 10 bolts rip apart very easy.
