oil pressure K5 Blazer 6.2L diesel 1984
Hello from France (sorry for English)
My problem: I changed my starter K5 (solenoïd smoked), since I have too high an oil pressure, 60 instead of 30 usual (dash), I drained and changed the oil filter, is there a report, I would check the pressure sensor, but I did not mark it on the engine. a photo, a schematic can help me. thank you in advance |
*Moved to 'Full Size K5 Tech'*
k5 oil presure
when you first change your oil it is cold as it warms up the pressure will drop.
I hold 80lb unless I've been running on the hwy then it drops to 60lb. after a few minutes it will be back to normal. |
