PLEASE HELP!!!!!
I HAVE A 78 K5 BLAZER. SO WHEN I BOUGHT IT THE 4WD WAS TOUCHY THEN A BOLT CAME OFF THE BARS OF MY LINKAGE SO I REPLACED IT. SINCE ITS BEEN SLIPPING INTO 4WD, NOW I CANT EVEN GET IT BACK IN 2WD. JUST PUT SOME GEAR OIL IN THE TRANSFER CASE. WONDERING IF MAYBE THE BOLTS ARE NOT SITTING IN THE RIGHT POSITION
RE: PLEASE HELP!!!!!
Because you state that you have trouble getting it back into 2wd, I will assume that you have the NP205 transfer case.
Here is how you adjust the shifter on this transfer case: http://i11.photobucket.com/albums/a1...NP205_diag.gif [ol][*]Put transfer case lever in 4HI detent.[*]Push lower shifter lever forward to 4HI stop.[*]Install rod swivel in shift lever hole.[*]Hang .200 thick gauge cover rod behind swivel.[*]Run rear rod nut against gauge with shifter against 4HI stop.[*]Remove gauge and push swivel rearward against nut.[*]Run front rod nut against swivel and tighten.[/ol] |
| All times are GMT -5. The time now is 09:41 AM. |
