-   Full Size K5 (1969-1991) GMT415 (1992-1994) Tech (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/)
-   -   rear seat belts (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/rear-seat-belts-26272/)
bestwrench45 01-04-2009 07:36 PM
rear seat belts
I have a 90 gmc full size jimmy,when I received it it was missing the rear shell,got a shell but now I have nowhere to mount the rear seat belts. The plastic housing has the same contour as the shell above the side glass but there are no holes for the seat belt,PLEASE ADVISE!!!
swartlkk 01-04-2009 08:00 PM
RE: rear seat belts
*Moving to Full Size Tech*
Could you explain what you are looking for in better detail? Are you talking about 3-point seat belts and the upper mount for this type of belt? If so, I do not believe that the rear seat in a 90 K5 has such a configuration... This would not be very secure if it were to attach to the fiberglass half top...
bestwrench45 01-04-2009 08:17 PM
RE: rear seat belts
yes, I am talking about the upper mount,I guess it's suppose to be a 3 point but I cant figure out where else to put the retractor,but like I said the contour of the retractor matches perfectly to the channel above the side glass but you are correct,bolting it to the fiber glass top doesn't seem to be a very good choice.
swartlkk 01-04-2009 08:22 PM
RE: rear seat belts
Sounds to me like you have a set of rear belts from a 92+ K5 which had a full body (no removable top).
rriddle3 01-05-2009 03:54 PM
RE: rear seat belts
*MOVED FROM DUPLICATE THREAD*
ORIGINAL: bestwrench45
ok so if this thing has the wrong rear seatbelts in the back ,can anybody tell where I can find the right belts,my haynes manualdoesn't show anything, and I've searched the web since I got this thing but I still can't find the right answer
DdayK5 01-20-2009 12:35 PM
RE: rear seat belts
have you already tried http://www.gotbelts.com/?
