-   Full Size K5 (1969-1991) GMT415 (1992-1994) Tech (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/)
-   -   steering column (https://blazerforum.com/forum/full-size-k5-1969-1991-gmt415-1992-1994-tech-42/steering-column-41858/)
t.lyttle 03-08-2010 09:29 AM
steering column
I have a 1990 K5. and i need a new column. i found one for 50 bucks but its out of an 87K5. Will it fit?
abig84 03-08-2010 09:55 AM
Yes it will fit. Some of the stuff maybe different but should interchange between the two. I have one out of a 91 k30 and its the same as all the other k5 ones I have laying around. Only problem I ran into was the clips for the ignition switch wwas different but the wires were the same color so I just spliced in the different clips
t.lyttle 03-09-2010 07:26 AM
mine is a tilt column...does it matter if the one in the 87 is not
