tbi issues....1990 5.7
I am having issues with my tbi.....I have spark,new icm,ecm,esc mod,throttle positioning sensor,fuel pump,in line filter,but I am not getting fuel to injectors....took injectors out and tested in another chevy truck they are fine....put noid light on them an no pulse.....help me....ps the truck will start if i pour gas down throttle body.....what am i missing???
So it's your fuel delivery system.
When you turn the key from off to the first position do you hear the fuel pump kick on? It should whir/buzz for 3-4 seconds. There is a fuel pump relay on the firewall. There are also two fuses for the ECM/Fuel pump on the fuse block. |
Fuel pump an relay are brand new....checked fuses also....theyre good....distributor ???
aiight. as far as im aware of the pick up coil in the distributor helps with injectors. try it. i think they are like 10 bucks.
im going to try the dist today...I hope it works cuz im already about 450.00 into this, and runnin out of funds fast
Using stock TBI base vs. bored unite
I tried a bored TBI unit on my K5 with 355 engine. I have a costume chip burned for my engine combination and the chip came with a high volume pump and high pressure spring for the pressure regulator. The engine is healthy with Dart 180 SHP heads, mild elgin cam, 9.8:1 compression. :icon_qtank:
The bored unit is very hard to seal and I ended up using JB weld to seal around the bores. When they bore the unit out the sealing area is about 1/16" thick, no good. I epoxied the unit to my adapter plate to make a good seal. Idle is bad "loopy", but when I get on it engine screams. I went back to my stock base TBI with injector pods and aftermarket spring/pressure regulator. Idle is far better, and all around driving is better. Unless you are beating the hell out of your engine or have a wild setup, stay with a stock TBI with better injectors and/or high pressure spring. Good Wheeling. |
Originally Posted by tattime
(Post 605360)
Problem fixed........it was the distributor ....apperantly this yr has cam sensor an crank sensor located inside of it
Good for you. I have had distributors go bad but usually no spark.
That is false, there is no cam or crank sensor in the distributor. Only sensor in the distributor is the ICM module.
| All times are GMT -5. The time now is 03:32 PM. |
