Transmission & Transfer Case Noises
when i shift gears from D to R, i can hear a loud bang coming from the transmission i guess, it's loud and i can feel the blow budging the truck violently.
but, when i shift to R from P it goes in smooth and quietly. any thoughts?
another strange noise comes from the transfer case only when i put it into 4L - i can hear a sound slimier to a whistle while i apply gas.
i don't know much about transfer & transmission guts, so any help will be helpful.
by the way the truck is 90, k5, 5.7L with 700r4 and np241c.
thanks in advance, yarin.
i need to check what "slop in the driveline" means unless you have some information for me.
i just put in new oil yesterday because i suspected the same thing, so there's a brand new oil in it and the noise stays the same..
the only thing i can think of is the new detroit locker i installed recently, so i guess i can pin point the exact location of the blow, but how will i determine if this blow is making damage?, after all the truck shacks really bad when i change gears.
You can have slop in the transmission, the transmission to transfer case coupling, inside the transfer case itself, transfer case to driveshaft coupling, the u-joints, and the pinion to ring gear engagement that can all add up to a clunk when changing directions.
Was it like this before the locker was installed? Did you install a lunch box locker (installs into the open differential carrier) or did you install a complete new differential carrier center section?
i installed a complete new differential, with a new gear & pinion. I've used a dial indicator to make sure the backlash is within the recommended range.
and to be honest, i really can't remember if the noises came after or before the installment.
the only thing i didn't do while installing the locker was to change the "position" of the pinion, i left it just the way it was and installed over it's setup, but eventually i got to a recommended backlash.
as far as other noises - sometimes when i apply the gas, release it and apply it again i can hear loud bang and i can feel the impact, but i feel it all over the truck so it's difficult to tell where the noise comes from.
and sometimes, the second time i push on the gas it goes in smooth, sort of speak. no noise and no vibration.
so, is it possible that even though the backlash is correct, there's a slop in that differential?
and, is there a way to isolate the noise, mean like removing the drive-shaft and hear if the noise is coming from the transmission or not?
