Window Problem
Ok, so when I try putting both windows up at the same time, it blows the fuse. Assuming this is not normal, I came here to see if anyone knew what could be wrong? Any help would be great.
Sounds like old motors drawing too much current.
The motors in it are pretty new. Any other ideas?
Could be a warped or dirty window regulators. Dirty channels that the glass runs in. Glass could be cockeyed in the regulator casing binding.
Faulty relay? |
I'll check it out tomorrow (its in the shop atm), and let you know if thats it. If I can't get it working, is there a way to install manual windows? The power windows are so slow that it wouldnt even really make a difference :P
LOL. You'd have to replace the power window regulators with manual window regs. $50.00 from LMC plus cranks. Probably have to cut a hole in the interior door trim as well.
Originally Posted by oisinirish
(Post 263561)
Unless you really want manual windows...
Get a multimeter and check to make sure theres nothing wrong with the wiring and/or get a window motor kit from lmctruck.com. $169 for a complete kit.
just roll one up at a time:icon_angel:
i had a suburban that was the same way. some windows didnt go down at the driver side, the rear right would blow the fuse going up. i eventually found a parts truck with all manual cranks. electric is nice when it works |
My windows go up so slow I was afraid to try both at once thinking I'd kill the battery! ha ha I thought about manual windows to with the problems I have, and since I'll need new panels anyway it might be worth it.
