88' K5 cuts out
Old 01-08-2019, 07:46 PM
Challupa Batmann's Avatar
Challupa Batmann is on a distinguished road
Unhappy 88' K5 cuts out
I have an 88' 5.7 TBI that cuts out pretty much under any condition. It typically takes between 5-15 minutes when idling, but when driving after first 5 minutes starts dying more frequently. It also periodically bogs down a bit every 2-3 minutes when driving, I think this eventually develops into the stall.
Recent Parts replaced/repaired:
Distributor, TBI rebuild, spark plugs, ignition wires, fuel filter, fuel pump, ecm, egr, and O2 sensor.
Any thoughts on where to start troubleshooting?
Old 01-09-2019, 02:29 PM
odat's Avatar
odat is on a distinguished road
check for a partially plugged cat
Old 01-20-2019, 04:11 PM
No Cat.
Update: Checked TPS, MAP, Ignition coils, and vaccuum.
Vacuum:
holds steady 20 mmHg drops to 15mmHg when rev'd a bit, rebounds pretty fast.
TPS
Full range - 0.5V - 4.7V
For checking coils, resistance check primary and secondary work most the time?
Coils:
Primary - 0.7 Ohms
Secondary - 9.88k Ohms
MAP:
0 mmHg - 4.3V
10 mmHg- 2.3V
15 mmHg -1.6V
20 mmHg-0.7V
Old 01-20-2019, 05:37 PM
Also, noticed today when it died there is a decent cloud of gas that shoots out the top TBI unit when it dies... Not sure if that is indicative of anything specific, but explains the gas soaked air filter and charred wiring harness I had to replace for injectors.
18ryaree
11-25-2017 03:27 PM
vanwinkle76
03-14-2015 08:31 PM
zerepdivad
10-31-2010 07:41 PM
Fat_Phil
02-20-2009 10:48 PM
GrooveK5
03-30-2008 10:43 AM
Quick Reply: 88' K5 cuts out
