auto to stick
Old 08-25-2004, 11:43 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default auto to stick
i've got an 88 k5 with a 700r4 which is about to crap out on me. anyone got any tips on swapping to a sm465 manual? will it bolt up to the old tranny mount and np208 transfer case? any help is appreciated. thanks
Old 09-09-2004, 05:10 AM
78K5SittinTall is an unknown quantity at this point
Default RE: auto to stick
Man I wouldn't be supprised if it would be a direct interchange bieng a Chevy and all, but one way to find out is to visually compare the two settups. Look at one with your 700R4 and one set up with the rock crusher. When I do this sort of thing I take a tape measure with me and compare crossmember locations between the two 1st. Over all tranny length will definately be a major factor. As far as whether a SM465 will bolt up to a NP208, don't know, but a visual comparison should tell you as well. Might need a special aftermarket adapter to connect the two. It's a Chevy, you know someone has done this already!
Old 09-09-2004, 09:42 PM
zero psi's Avatar
Retired Admin
yeah, i guess its a really popular swap, but i couldn't really find any info on it. I did find out that the pedal assembly just bolts right in and when i had my carpet up to weld in new floors, the transmission tunnel had the outline where to cut for the shifter. so i guess its a pretty easy swap. just gotta find everything i need at the bone yard and remember to bring a tape measure. thanks.
Old 09-24-2004, 11:20 PM
zero psi's Avatar
Retired Admin
well, my tranny's getting worse, so im off to tha bone-yard tomorrow morning to get everything i need. from what i found out all i need is the tranny, bellhousing, shifter, pedal assembly, and linkage, and of course a new clutch. i think thats it. wish me luck, i may need it. im a body man pretending to be a mechanic[8D] anyone want a 700r4 for a rebuild?
Old 09-26-2004, 10:51 PM
zero psi's Avatar
Retired Admin
well, no luck. all the trucks there were automatics[:@]. off to ebay i go! it is kinda funny how there were only about 15 chevy trucks there and about 200 fords.
Old 09-27-2004, 01:20 AM
01xtreme is an unknown quantity at this point
That is pretty humorous that there were alot of ford's for sale. It sucks that you couldn't find whay you were looking for. You'll find it when it's time.
LannyL81
08-08-2010 01:01 PM
blazeC2
06-06-2010 01:46 PM
88K5blaze
02-01-2010 09:32 AM
aquaelvis
09-11-2009 01:07 PM
hillbillyinOhio
07-12-2006 04:18 AM
Quick Reply: auto to stick
