Direct bolt in Axles K5
Old 09-22-2016, 11:29 PM
zdunn's Avatar
zdunn is on a distinguished road
Default Direct bolt in Axles K5
Hey guys new to K5's and off road trucks in general. I just bought a 80 K5 with a 12 bolt rear that needs an entire new housing. What years and model of trucks can i pull a direct replacement just want to bolt in and go. I like the idea of a 14 bolt but from what I understand takes a little bit of welding and modifying. Thanks in advance
Old 09-23-2016, 12:52 PM
abig84's Avatar
10bolts out of the newer k5s will bolt right in. my 84 k5 blazer had the front and rear axles out of a 77 k20 pick up truck.
as far as the 14bolt goes, someone correct me if im wrong, but you will need a 14bolt out of a 3/4ton truck for the perches to line up. i know the 1tons are different as i stole a set of axles out of a 80s 1ton to put in my 85 k5 blazer. the front dana60 matched up but the shock mounts and spring perches had to be cut and moved.
the only problem you might run into is different sized u-joints when going to different years. that 84 with the 77 axles i had to run a goofy universal u-joint with two different sized caps on it
also 14bolts are gonna be 8 lugs if you go with the full floating axles. so the easiest swap in will be a gm 10 bolt, just gonna maybe have a issue with the ujoints
Old 09-24-2016, 05:57 AM
zdunn's Avatar
Sounds good I appreciate it. Hopefully i'll have er driven soon
thewickedk5
08-08-2010 01:36 PM
chevy Blaze
Engine & Internal
01-13-2009 08:25 PM
S10Blazer
01-29-2008 01:29 PM
chevyrocksu
Headers, Intake, & Exhaust
11-25-2006 03:29 PM
webbyj883
Suspension Tech
09-09-2005 02:15 PM
Quick Reply: Direct bolt in Axles K5
