need help with voltmeter
Old 11-25-2009, 11:32 AM
spark plug's Avatar
spark plug is on a distinguished road
Default need help with voltmeter
im trying to install a voltmeter in place of the factory amp guage in my 74 blazer. but having problem with getting the guage to show the correct voltage. i ran a new power and ground wire to the guage but it just barely moves the guage. there is 3 prongs on the back of the guage, and i got the guage as a factory replacement from LMC parts. from what ive read 76 and newer blazer have the voltmeter. so can someone send me a diagram showing my how it's wired? ive tried several different combinations of power and ground to the 3 posts and none seem to show the correct voltage. some make the guage show way too high and others make it go backwards. please help. Thanks
Old 11-27-2009, 10:34 AM
Doubletap308's Avatar
Doubletap308 is on a distinguished road
I don't know why you have 3 connections but I'm thinkin one may be for illumination.
Check this out, it saves me from typin it all out and you can save it to look at again
http://www.sunpro.com/publish/2007/0...ench_16429.pdf
(It's NOT in French, I don't know why it says that)
As far as the meter running backwards, that means it's hooked up incorrectly. Also remember that it won't show a lot of voltage until it's up past idle speed, so you probably had it hooked up right when you said it barely moved the gauge.
Hope that helped!
EdC
07-31-2015 12:36 PM
MikeMSU
01-04-2015 04:05 PM
NTL1991
01-10-2009 11:22 PM
lionel2
03-13-2008 01:09 PM
Quick Reply: need help with voltmeter
