Rear power window problems
Old 10-13-2007, 11:57 PM
JTAF's Avatar
JTAF is an unknown quantity at this point
Default Rear power window problems
1990 K-5 4wd with a rear window that wont go up. I have replaced the motor in the tailgate, and when I push the switch the window will sound like it goes down but not up. I was told that the dash switch should be replaced. Does anyone have any experience in this area? Thanks!
Jeff
Old 10-14-2007, 12:01 AM
Default RE: Rear power window problems
If you hotwire the motor, will it go up then?
*Moving to Fullsize Tech*
Old 10-14-2007, 01:46 AM
Chevy Lover's Avatar
You may have a faulty switch in the rear panel. If you open the tailgate and remove the latches there should be a switch on each side. These switches (if I recall correctly) are supposed to prevent the window from going up if the latch is open. You should be able to jumper the connectors to bypass the switch as a test to see if the window will now go up.
You can do this with the tailgate open.
http://lmctruck.com/icatalog/bzc/0025.aspmotor cutout switch #22
I don't know for sure, but I have a hunch....
Old 10-14-2007, 10:09 PM
JTAF's Avatar
Thank you, for the words and the link. I will let you know what happens.
Jeff
e602
91
03-08-2015 04:53 PM
bigslik20
08-09-2011 11:32 AM
Campesino
09-21-2008 12:35 PM
ClayKuch
10-14-2007 08:49 AM
nbwebb
06-24-2007 09:22 PM
Quick Reply: Rear power window problems
