Tailgate window motor
Old 01-10-2011, 11:50 PM
Def87k5's Avatar
Def87k5 is on a distinguished road
Default Tailgate window motor
I just picked up a 87 k5.The rear window was missing the motor and the wires were cut i also have a L shaped rod with an L shaped end on each side i know where it goes but not what it does or connects to at the ends and i found a spring about 2 inches or so long. i have a new motor. i can make the window go up and down with a drill and open the tail gate. Main question is where does the motor mount and what else am i missing? i can find no pictures or good diagrams. Any pictures or something would be awesome.
Old 01-11-2011, 08:37 PM
I have a complete power tailgate sitting in my shed, but I'm not hauling that out of there anytime soon, sorry.
I thought I had an exploded view somewhere, but I can't find it anymore...
I believe the motor itself bolts on up at the top of the tailgate just to the driver side of center.
The rods/etc that you mention sound like they are part of the lockout mechanism that makes it so the tailgate cannot be unlatched without the window being all the way down.
Old 01-11-2011, 08:52 PM
Def87k5's Avatar
ok but if i connect the motor to the cable it only goes a little over half way up the tailgate and the threaded holes in the motor dont line up anywhere, am i missing a bracket? thanks
Old 01-11-2011, 08:56 PM
Maybe take a picture of what you have on the motor as well as your tailgate?
You may not have everything adjusted properly and something may bind half way up.
Another possibility is a weak spring in the window regulator. The spring helps the window up.
Old 01-11-2011, 11:11 PM
Def87k5's Avatar
I can roll the window up and down with a drill with no problem, i just dont know where the motor mounts. I cant find pictures of what one should look like. i found a 83 suburban at the junkyard and it had a different setup, it had the motor mounted on the regulator on the right side with no cable.
Old 01-12-2011, 08:24 AM
agb1976's Avatar
agb1976 is on a distinguished road
I think the Suburban and K5 tailgate is similar, Lmc truck has some what of a picture if that might help, pg 24 and 25 in the blazer catalog. http://www.lmctruck.com/icatalog/bzc/full.aspx?Page=24
good luck
Old 01-12-2011, 12:14 PM
Def87k5's Avatar
ya i saw that one but none show where the motor mounts
Old 01-14-2011, 11:17 PM
Def87k5's Avatar
K i found it on a video titeled k5 blazer tailgate-update. im missing the motor bracket.
Old 01-16-2011, 03:32 PM
Def87k5's Avatar
Does anyone know where i can get one i cant find it anywhere?
Old 01-17-2011, 06:43 PM
abig84's Avatar
id say junkyard but its hard to find these things in the junkyards anymore. i just checked ebay and didnt see any
http://www.autozone.com/autozone/par...mString=search
looks like autozone sells the complete assembly
Quick Reply: Tailgate window motor
