-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   1992 blazer k1500 (https://blazerforum.com/forum/general-chat-34/1992-blazer-k1500-51766/)
k1500mudder Nov 20, 2010 05:03 PM
1992 blazer k1500
i got a v8 4x4 k1500 and my fuel gauge stoped working.. i need help to fix it any ideads? i was told could be fuel ground wire but i cant find it plzz help
hawkster0001 Nov 20, 2010 05:40 PM
could be the float sticking, give the tank a couple whacks with a mallet (without denting it) and see if that makes any difference,
4x4blazerguy Nov 20, 2010 07:15 PM
Is this a fuel injected truck? If so it could be the sending unit. I believe they were part of the in tank fuel pump. My 86 F250 which is not a FI system but has in tank fuel pumps had that same trouble. The gauge quit working on my front tank. When I pulled the pump the sending unit was part of the pump & there was a bad wire. I ended up replacing the unit. At that time they were not available separate & were a dealer item only. Now that has changed. Fixing the wire was really not an option because the fuel screen was starting to come apart & I figured the pump itself was not far behind from going bad & didn't want to pull the tank again. I believe the ground wire is on top of the tank.
