1994 Chevy Blazer 5.7L TBI
Old Jun 19, 2025 | 04:35 PM
Goofy98's Avatar
Goofy98 is on a distinguished road
Mr TheJimmyMan, have located several problems.....
1 the power steering pump in leaking at the pulley bearings causing lose of vacuum
2 thermostat is bad and heater core
3 EGR valve and iac valve are both bad
4 possible retarded time is what a mechanic called it
So on the search for all these parts
Old Jul 4, 2025 | 12:39 PM
Goofy98's Avatar
Default Update
Hey all, back again.. had the truck running before a tune up kit, then it started a crank no start. So we thought it may be the timing.... So we Manually put it back in time, wouldn't crank, just back fired several times. So then we proceed to put it back like we found it before we started messing with it. This truck still will not crank. Any help or tips would be greatly appreciated. It has gas, it's making it to the injectors because we can smell it strong. Thanks in advance for any and all help/tips
Old Jul 6, 2025 | 08:09 PM
TheJimmyMan's Avatar
TheJimmyMan will become famous soon enough
Is it possible for you to take a video of you cranking it? Then post it on here. I don't know what else it could be.
Old Jul 10, 2025 | 09:21 AM
Goofy98's Avatar
It won't crank at all....well crank no start
Old Jul 11, 2025 | 09:27 AM
This all I have left to be able to offer to you at this point. I can send you something from the book, if you want to see a specific problem rom the pages.
Old Jul 16, 2025 | 07:58 AM
Goofy98's Avatar
Sorry for not responding TheJimmyMan. Thank you so much for these pics of manual, of which I do not have ....will troubleshoot everything it says. Again thank you for all your help sir
Morgan307
Apr 6, 2025 03:57 PM
ctmoseley
Engine & Internal
Dec 19, 2018 03:34 AM
debago77
Jun 26, 2017 02:33 PM
deathman
Aug 14, 2011 11:25 PM
exilous
15
Mar 24, 2009 04:31 PM
