1996 Blazer
Not sure if this is the right place to post it, but I'll give it a shot....
Today, I was looking at a car lot looking to buy a chevy blazer, and found a '96 4 dr, LS, 157,000 miles. It looked pretty good on the outside and interior, but I did not have a chance to take it for a test drive due to time constraints. Probably will in the next week. Now, my questions shall begin. I have been doing some research on Edmunds, and some of the reviews are horrendous for this model. 1) Cooling system problems. Some reviews talk about the factory coolant system being made up of metal/aluminum parts, but the recommended coolant kills it. True or not? 2)AC issues. Seems that all the S10 Blazers have this problem, so not shocked. My parents' '98 Blazer's AC went last summer, $1200 to fix, so its not going to get fixed 3)Issues with vacuum lines being weak, and completely crumbling. 4)Overheating with the AC on. Apparently this is because of a bad fan...? 5)Radiator issues? 6)Apparently VERY costly repairs over time. 7) Thermostat issues? If ANYONE could give me some info, that would be great. Thanks, Nathan:icon_doh: |
In my opinion..Lack of maintanance is a huge issue with these..As far as the test drive goes, make sure you test drive it for atleast 50-60 miles this should give you any indications if the ses light comes on..Don't do what i did and just drive it around the corner and back lol
Originally Posted by reelbroke2
(Post 229464)
I defenately am going to have a mechanic that my family is friends with check everything out, like tranny, engine, etc. Have you had anything happen with the questions I listed above? |
With the exception of #2 I have had these type issues with all other cars that I have owned, whether they were GM or not. They are not Blazer exclusives.
If the SES light is on Take it to advance auto (it's free) and have them check to see what code it is.
Originally Posted by rriddle3
(Post 229516)
Anyone else have any of these problems?
1) I ran Dexcool in my '96 Blazer until crud plugged up the heater core after a coolant flush. A backflush of the heater core fixed it twice, but after it plugged up a third time I took it to a radiator shop that flushed each component separately and then refilled with plain ol' green coolant. I haven't had to replace any components though.
2) I had to replace my AC system a couple months ago. Not cheap, but it blows COLD now. 3) No issues with vacuum lines other than replacing the reservoir mounted to the hood. 4) Haven't had any overheating problems. 5) No radiator issues. 6) I have had to sink some money into repairs, but probably no more than most other vehicles this age. 7) No thermostat issues. |
1) cooling system, when you buy a used vehicle, whatever make you get, flush it out COMPLETELY and change the thermostat.
2) A/C Issues. Proper maint and replacing parts is common in most vehicles, the A/C in my 89 hasn't worked since 92, thus I have windows that do work. 3)99% of all vehicle vac lines need to be replaced when they break down. GM has always had issues with vac lines, its like the old silver paint issues GM had, you want good vac lines get a Honda. 4) probably either a clogged radiator, poor coolant flow (water pump) or a bad fan clutch 5) radiator issues, I feel your pain, I have those too, only real issue with a radiator is leakage, in that event replace it. 6) Here we go with proper maint again, maintain a GM vehicle on a regular basis it'll run forever, abuse it and it'll be towed from all over town,(My 89 runs like new except for the old age thing going on) 7)Thermostat issues, change the thing whenever you change the antifreeze, no issues |
Originally Posted by wolfen
(Post 230408)
