2000 blazer. After heater core was replaced
After heater core was replaced ignition was in a stuck or locked position but can be forced passed to start. You have to turn key back slightly or starter will stay engaged. Also with this issue intermittently windows, dash lights and apparently shifter is not working. Sounds like I have a stick shift and dont know how to drive it. Just tearing up gears. Shut it off restart it dash lights work then everything else works too? It also appears the shifter sits lower on the column. Is that possible? Any clues to where I need to start looking for the issue after dash is dropped again? Thank you in advance.
A large amount of the truck's electronics runs thru the ignition switch (and by switch I mean the unit with all the wires going thru it in the column) if that goes bad or is damaged you can get all kinds problems that don't seem to be connected throughout the truck.
50lb_cat
10-03-2017 03:40 PM
Tuna
03-22-2015 10:39 AM
Matty man
11-22-2011 08:52 PM
