2000 intake manifoid thread lock or sealant?
Old Apr 3, 2013 | 07:15 PM
Originally Posted by 1999windstar
...I didn't put thread lock on the lower intake bolts. Is this going to be a problem?
Yup, see post #8.
As for the smell, there might be coolant on the exhaust manifolds, or exhaust pipe, that needs to burn off. Make sure there are no leaks.
Old Apr 4, 2013 | 05:51 PM
1999windstar's Avatar
1999windstar is on a distinguished road
ok I messed up. Should I take each lower intake bolt out one at a time put med thread lock on and re torque it? The blazer is 250 miles away and he needs it to get to work
Old Apr 4, 2013 | 07:39 PM
Yup, that's how to do it, one at a time. The two front bolts are "neatly tucked away" under the AC compressor and alternator, so they'll have to be moved to get at them. The rest of them are in plain sight. It's not like they're going to walk out right away, it usually takes a while.
Old Apr 5, 2013 | 08:12 PM
I have another question. When we took the lower intake off, the fitting that the pcv valve hose connects to had a orange foam buildup on the inside of the intake. I not sure if it is on the upper or lower intake but is was quite a bit of this buld up there. Could this be from the transfer case filling with transmission fluild? My son says he still smells something but he doesn't think it is antifreeze. I didn't have time to check the fluid level in the transfer case. Would is be burning it and making a smell?
Old Apr 5, 2013 | 08:38 PM
The orange crud is probably residue from the coolant getting into the oil. If it were burning trans fluid, you'd have serious white clouds of smoke, (not steam) from the tail pipe. Very easy to check the transfer case fluid level: Remove the upper, (fill) plug from the rear of the transfer case. If fluid runs out, the transfer case input shaft seal is leaking. The transfer case must be removed to replace the seal. Good idea to replace the vacuum switch on the transfer case at the same time.
DetailersDomain
Detailing
Sep 24, 2011 07:08 PM
shaggy_5420
Jun 29, 2010 02:15 PM
ChrisC
Mar 1, 2010 09:21 PM
NVANZEE
Feb 17, 2009 08:57 PM
bigt
Feb 5, 2007 12:18 AM
