2000 s10 trailblazer vacuum line
I have two lines that run to the driver side fender just a few inches off the fire wall. I know one of the lines has to be plugged so the 4x4 will work. The second is unhooked and can’t find where it hooks up at.
Have a look at the vacuum accumulator...Its a black plastic ball inside the drivers fender and real hard to see but if you use a mirror or get your head right down there you can see the nipple of it sticking out where a vacuum line would slip on to...I tried to find a picture that I have seen on this site but there is so many vacuum related threads.
Originally Posted by Strangerock
(Post 683062)
Thanks I will see if that’s it.
Ive got the engine vacuum and it T's off . 1 goes to the black ball and the other t's off again , 1 going to the 4x4 vacuum switch on the firewall the other connects to a small hard line that disappears and i cant see where it goes.
(Post 683062)
thanks for help. That line ran to a hard black line that Help control my vent select switch |
