2003 Blazer LS 4X
Have problem with turning my car as sharp as it can go it seems to push the wheel enough to make it slide not just roll. It does this turning both ways. And this is the second Blazer I have owned that did the same thing on sharp turns both ways as well. My 1996 also did it so can someone tell me if there is something with the turning radios on Blazers
Is your 4wd engaged?
Have you measured your turning radius against what the specification is? (You can probably Google that info). Maybe you are asking it to do something it cannot do. Also are you running stock tires and suspension? Over-sized tires can limit how much the steering wheel can be turned. FYI: Please use more periods and full sentence structure. It makes the post easier to read. :) |
