95 Blazer (2nd gen?) seat swap
New member here- looked through the forums and am trying to find info on swapping out or replacing the seats, mainly drivers side, on a 95 Blazer, column shift w/console. I’m under the impression this blazer is 2nd gen due to having the vortec engine...anyway, just curious if there is a definitive answer on year and models that will swap. I’ve read S10’s, Camaro, etc....
S10, sonoma, jimmy, blazer, bravada. I'm not sure of the differences for seat brackets from 95-98 and 99-05...
Originally Posted by DonL
(Post 709130)
For a 95 Blazer, you'll want to look at 95-97 Blazers, Jimmys, and Bravadas. Also, 94-97 S-10/Sonoma Pickups.
1998+ use a different set up, but could be modded. Now as far as other vehicle seats fitting....that is limitless. It comes down to how much work you want to put in. Cavalier and Camaro seats supposedly bolt up to the seat rails. If you only wanna unbolt and swap, then look into the similar year/models. |
Thanks!
I'm most likely gonna be getting some new seats Sunday at pick n pull. Mine are ripped to shreds and covered in mud anyways lol. N Jensen, I'm glad you pointed out about the later second gens. I didn't realize, and would probably have gotten the wrong ones!
| All times are GMT -5. The time now is 02:55 PM. |
