-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   97 blazer 4x4 problems (https://blazerforum.com/forum/general-chat-34/97-blazer-4x4-problems-87271/)
HondaChevy 09-21-2014 09:05 PM
i have a 97 chevy s10 blazer 4x4 with the 4.3 i am have problems with my 4x4 it will not engage i have replaced the vacuum switch on the transfer case and i have replaced the actuator under the battery with the cable. the 4x4 lights come on when i switch from 2wd to 4hi and 4lo. now that i have changed the vacuum switch i am not getting vacuum to the actuator and the reason i changed it was due to the old one was stuck on 4x4. any help would be appreciated thanks.
chris015 09-21-2014 09:16 PM
well..
if no vacuum to it how will it operate?
follow the line to the engine and see whats broken. I cant remember where it runs,but unless its attached to the manifold then ofcourse it wont work.
HondaChevy 09-21-2014 09:32 PM
i have vacuum to the switch on the transfer case that i replaced but it seems like its not sucking the ball on the switch for it to switch the vacuum to the actuator. i have chased the lines and i did repair one that had a hole. when i put in the old switch that is stuck on 4x4 i get vacuum to the actuator but even then when it was on 4x4 with the vacuum on the actuator my front diff would not engage.
