-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   97 s10 major fuel leak where fuel lines go into spider (https://blazerforum.com/forum/general-chat-34/97-s10-major-fuel-leak-where-fuel-lines-go-into-spider-78886/)
Big Eazy 04-26-2013 07:05 PM
How can I get the 2 plastic tubes out to change the Orings?
:icon_doh:
bear159 04-26-2013 07:21 PM
On mine there was a small clip you had to pull out where the lines meet the injector, then you could just pull the lines off.
Big Eazy 04-26-2013 07:58 PM
This one just has the retainer clip that holds the fuel lines down but nothing appears to be holding the plastic tubes in place maybe they just pop out?
okiedoak20 04-27-2013 12:48 PM
if you can remove the retainer clip, check for a small bolt if not the tubes chould wiggle and pop out, but the lines do need to be unbolted from the back of the motor to have enough room to move
