98 blazer won't start need advice. ...
Old Feb 19, 2013 | 02:25 AM
CaldwellJonathan's Avatar
CaldwellJonathan is on a distinguished road
Exclamation 98 blazer won't start need advice. ...
I own a 98 Chevy blazer an it won't start sounds like its not getting gas so I ck the fuel pump an it's pump like a champ ck the firing mechanism an it seems to be fine ck all the fuses an they're all good. What else could it possibly be I'm stumped????....
Old Feb 19, 2013 | 04:15 AM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
fuel pressure check, and a spark test is what you should have done if you've done both these tests what are the results and readings?
Old Feb 19, 2013 | 08:15 AM
I've ck the pressure it holds at 50psi seems to b fine idk what a spark test is. I've toke a wire off the firing mechanism an watch for sparks when someone else cranked it an it definitely sparks.
Old Feb 19, 2013 | 08:43 AM
chris015's Avatar
50 is too low. Change fuel filter then check it again. if its still below 60,time for a pump. Yes these things are this sensitive on pumps. Only buy a ac delco or delphi pump.
Chic_Bowdrie
Mar 14, 2014 08:37 AM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
