98 GMC jimmy won't start multiple codes
Old Jul 4, 2023 | 06:31 PM
Chrisxxx9876's Avatar
Chrisxxx9876 is on a distinguished road
Default 98 GMC jimmy won't start multiple codes
Was running fine and wash windshield off with waterhose and started but was misfiring bad and after 30secs died and won't start,code reader listing multiple codes from po605,po103,u1193,crankshaft and camshaft position sensor codes and many more.Bad ECM?maybe shorted out from the water?
Old Jul 4, 2023 | 10:42 PM
GeorgeLG's Avatar
P0605 is an internal VCM problem. First I would check the power fuses for the computer:
  1. ENG1
  2. ECM1
  3. ECMB
After that, look at the ECM and its connectors to see if the thing got wet amd make sure that everything is clean, dry and tight. After that you can either open the ECM to look for solder joints that need to be reflowed or consider a new ECM (I don't say that very often).
Another possibility is that the class 2 data bus got corrupted but you will need a scope to look at that. I am not sure if that can cause a P0605 code or not.
The question is that if a water hose to the windshield did in fact kill your ECM, that needs to get figured out before spending engine computer money.
George
Old Aug 16, 2023 | 05:47 PM
Default Changing ECM with one from junkyard,98 jimmy
Would I be able to swap ECM from 98 jimmy with one from same year?
Old Aug 16, 2023 | 06:10 PM
GeorgeLG's Avatar
It would also need to have the same relevant configurations and options. Engine and transmission for sure and possibly 2/4wd and other features such as ABS, etc.
George
95vortec4.3
Aug 16, 2013 06:57 AM
7outblazer
May 24, 2011 07:28 AM
cartunez2004
May 17, 2011 06:41 AM
acslip
Nov 15, 2009 05:10 PM
JediKnight2
Apr 17, 2008 05:46 PM
