99 blazer window problems
Old Jan 22, 2024 | 12:24 PM
ZackH96's Avatar
ZackH96 is on a distinguished road
Default 99 blazer window problems
99 Chevy Blazer window falls into door, the window motor does go up and down but for some reason the glass just falls away from it help please 🥺
Old Jan 22, 2024 | 01:30 PM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
You're going to have to open it up and see what gives. It should be a few screws holding some things together. Then you pop the panel off and lift it up. It's best if you can find where the pins are in the back of the panel and reach in there with a pry tool so they don't break off or damage the panel.
Old Jan 22, 2024 | 01:45 PM
ZackH96's Avatar
Default Window problems
Will check it out, unfortunately the person I bought it from destroyed the door panel pins
Old Jan 22, 2024 | 02:23 PM
I've done a few of them in myself. They aren't a bad item to keep a few in stock, they aren't expensive and they aren't too big.
strykerld
Mar 14, 2019 03:30 PM
199_Blazer
Sep 11, 2013 07:59 PM
terbates
Feb 20, 2012 11:16 AM
noom14921992
May 22, 2008 09:54 PM
nbwebb
Jun 24, 2007 09:22 PM
