Airbag lights on
well frost I was looking for the mudule for the air bag but where should I start the scanner only day infallible restraint mudule no po number check under the seat for yellow plug didn’t see any check center console near the back didn’t see any unless it’s under the rug no opening to access it the only think I didn’t wrong is. When I was changing the pitman arm I think the steering wheel spin around not sure any help I appreciate it thank |
1 Attachment(s)
Originally Posted by Johnny Colon Sr
(Post 687830)
well frost I was looking for the mudule for the air bag but where should I start the scanner only day infallible restraint mudule no po number check under the seat for yellow plug didn’t see any check center console near the back didn’t see any unless it’s under the rug no opening to access it the only think I didn’t wrong is. When I was changing the pitman arm I think the steering wheel spin around not sure any help I appreciate it thank The one between the front seats is under the carpet. You have to cut the carpet with a utility knife to get at it. It is worth unplugging the connectors and reconnecting them for each of the modules. https://cimg0.ibsrv.net/gimg/blazerf...6274a2fb14.jpg 1999 SIR component locations. |
