Any good junkyard mods for a Blazer?
More comfortable seats. Tire carrier, if you don't have one. Skid plates, if you're into offroading. Different torsion bars, if you're 4 wheel drive. Grabbing a rear end from a Blazer with the RPO code "G80" to get a locking rear differential (This is on my to do list).
ad244 alt mod from a full size pickup... can get them from I believe 1999-2006 silverado 1500's amongst others... If you search up ad244 alt conversion it will come up with all the models it came on. alts are pretty cheap from the yard.
145amps instead of the usual 80-105amps.
If you do this, make sure you check the alt case at the yard to make sure its the 145 amp model. All that will be needed to do this on your truck is about an inch, to an inch and a half longer belt, 1 grade 8 1/4" bolt and a some washers if the bolt is too long.
Intrepid Efans. I did the jimmy hood mines not color matched but I only paid $10 for it
astro van hydro boost brake setup. Overhead consolel if you don't have one. Full front end swap. I got my trailer hitch from the yard for $25 and it was virtually brand new.
