Anyone know how to get to this bolt?
Old Mar 22, 2008 | 10:22 PM
Taymacjack's Avatar
Default Anyone know how to get to this bolt?
Well, the time has come for me to replace the infamous leaky oil cooler lines. I need to replace the set that goes from the remote oil filter to the engine mounted adapter. I started to remove the lines, but it was starting to get dark before I could figure out my problem. The problem is that I cant get to the bolt that attaches the lines to the engine mounted adapter (as seen in this picture).
Anyone have any tips and/or tricks?
Old Mar 22, 2008 | 10:25 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
Default RE: Anyone know how to get to this bolt?
i usually use a socket on a ratchet for that one
Old Mar 22, 2008 | 10:38 PM
thegr81's Avatar
I would either try a socket and ratchet from what looks like the upper side for more room if there is any of a ratcheting wrench would probably work better for that tight of an area!!
Old Mar 22, 2008 | 10:43 PM
cant get at it from the top use a 1/4 inch ratchet if the 3/8 is too big and most ratcheting wrenches heads are too big to fit between the cooler lines
Old Mar 22, 2008 | 10:56 PM
Taymacjack's Avatar
have you guys done this before?
Old Mar 22, 2008 | 10:59 PM
ive done it many many times
Old Mar 22, 2008 | 11:04 PM
Taymacjack's Avatar
im just wondering how to get to that bolt...
Old Mar 22, 2008 | 11:05 PM
2wd or 4wd?
Old Mar 22, 2008 | 11:08 PM
nevermind its a 4wd pull the frfont skidplate cover off its right there
Old Mar 22, 2008 | 11:16 PM
Taymacjack's Avatar
never mind. I found a better solution
http://www.automotiveforums.com/vbul...d.php?t=764277
