Available Wheels?
Old 11-15-2017, 05:29 PM
Chris W.'s Avatar
Chris W. is on a distinguished road
Default Available Wheels?
Hey Guys, I am new here and new to Blazers altogether. I just picked up a 2000 model that's 4wd. The factory rims are all 4 leaking around the bead and I don't like the look to begin with. I am interested in possibly putting on some other wheels that came off of something else. I don't have a ton of money for custom wheels. What out there fits nicely on our 4wd blazers? That also doesn't require modifications?
Old 11-16-2017, 02:09 PM
chevyriders's Avatar
The lug pattern is 5x4.75
Corvette wheels are a common choice, and c4-c6 are a direct bolt up for 4wd...but be aware a lot of c5 and c6 wheels are staggered(front and rears are different sizes) so you will need to run 4 fronts, or 4 rears to avoid damage to your 4x4 system.
Trans am, firebird, and older Camaro wheels are the same bolt pattern also, but to the best of my knowledge only the newest style transam wheels will fit without rubbing on a 4wd.
Please note: 5x4.75 is NOT the same as 5x120, despite what people may tell you, there is a .65mm difference. That may not seem like much, but it puts extra stress on lugs and can cause them to shear...some people have successfully ran 5x120- but others have had lugs shear. I highly recommend against running 5x120
Old 12-01-2017, 02:06 AM
Private_Ops's Avatar
Private_Ops is an unknown quantity at this point
Honestly? Another set of factory wheels. Least trouble, least headache, guaranteed to work no issues.
Also, there is an "aftermarket" (I say it that way because chevy had a factory wheel that looked (had same specs to) the exact same) wheel that will work just as well as a factory wheel.
https://www.ebay.com/itm/15-Inch-Whe...dTq3aV&vxp=mtr
Old 12-01-2017, 05:46 AM
blazen_red_4x4 is on a distinguished road
Early 2000's 16" Camaro/Firebird wheels fit nicely and actually look like they belong
Old 12-01-2017, 07:54 AM
Those do look nice and clean
altoncustomtech
Performance & Brainstorming
02-19-2011 11:23 PM
CostaRicaConnection
Nitrous, Super Chargers, & Turbos
03-22-2007 11:02 PM
hayfieldfarm
Engine & Internal
01-05-2007 09:13 AM
cherryred4x4
Suspension Tech
19
09-08-2006 08:08 PM
Quick Reply: Available Wheels?
