-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   Bigger heads or new block completely? (https://blazerforum.com/forum/general-chat-34/bigger-heads-new-block-completely-70979/)
chunkster5979 05-25-2012 08:52 PM
I want a little more power out of my truck and i was wondering what would be the more reasonable choice. I could go for bigger heads and bore it out to get a boost in power.
Or should i just run this engine into the ground and find and 350 from like a camaro or rebuilt from somewhere and replace it with that.
Right now its got a 305 with the 700r4 transmission and only about 160HP.
cleburne red 05-26-2012 08:05 PM
The problem with a 305 is the bore is too small. And you can never bore it enough to hit that 4" bore a 350 has. Having said that, the same performance stuff that works on a 350 will work on a 305. Heads, cam, intake, will all boost the power of a 305. If you're looking for real power, though, the 305 will never cut it. The bore is simply not big enough to breath enough to make any power. 350's are so cheap they're practically growing on trees! That's the route I would take to get any horsepower.
chunkster5979 05-28-2012 06:37 PM
Thanks ill probably just do that then, hell I go the extra mile and do the whole powertrain, and just rebuild the tranny if its not in to bad a shape
